mrshoeit said:
Can you tell me if a NV4500 trans came in a 1999 dodge 3500? All I know is its a 5spd. I have a friend that has one that I think I could buy from him cheap. Is there alot of mods to make if work?
Mrshoeit
You need to adapt it to your engine, and you need to adapt it to the D20 transfercase, unless you want to use a dodge transfer... I don't know if their version of the NP205 will bolt to an NV4500 or not, but it would be a great match if it did (also, I don't know if the drop is a driver side one... hmmm you might need to adapt a transfer no matter what...),... Then you can get the adapter to the engine from on of the bronco vendors or advanced adapters... will be pretty pricey, but in the end you will have one hell of a transmission... Personally I say go for the ZF, it is an easier swap, and all FORD, but that NV4500 is bulletproof in the broncos...
Dave
