o2 sensor location for mustang efi
oldiron
I've looked for some good pictures of where to mount the o2 sensors, but can't find any good pictures. I'm running stock factory '77 manifolds. Everything I find is for long tubes or the shorties. How far behind the manifold is preferred? Pictures would help tremendously.
Greg
As close to the engine as possible while still sampling all the cylinders.
I think Ryan used to say that it was ideal between 9" and 12" from the rear-most cylinder. So for the driver's side, 9" to 12" or so back from #4 cylinder port. Which would probably put it somewhere about 6" or so down the exhaust tube past the connection to the manifold.
Same for the driver's side and #8 cylinder exhaust port.
Don't install the bung at the bottom of the tubing, because you don't want the sensor pointed straight up.
I should add, if it wasn't obvious, that was for factory Ford fuel injection. If you have aftermarket and only one sensor, then you want it near the Y junction where the two become one.
So if you're making your exhaust still, you want your Y to be as close to the engine as possible.
With two sensors this is not an issue.
