Off-Road tire pressure -- No beadlocks
kayakersteve
Western NY State
I've been playing with tire pressure and traction. Wondering how low I can go when off-road without significant increased liklihood of popping the bead. I know beadlocks help with this, but I'm not using them at this point. What is opitmum pressure for all-around off-road traction and durability??
Running KM2's 31"
Madgyver
Bronco Madman
10 - 12 psi on regular type wheels. I usually always air down in soft sand when playing.
malonejy
Ditto on what Mad said. I just installed some beadlocks yesterday though ;D
In rocks I was going down to 15. I could wrap the radial tire around rocks and was getting real close to getting pinch flats where the tire would fold up to the rim.
In the soft stuff, single digits worked great. I think the lowest I ever ran was 6. No hard turns or side loading.
Amac70
ME
boy you guys are on the conservitive side. moab i run about 8 or 9. sand all be down to about 7-8 usually a pound or two higher in rear then front. snow same thing 8-10. i wouldn't hit the sand with anything more then 14. i notice the air pressures in the sand a lot more then anywhere else.
Madgyver
Bronco Madman
I've been down to 8 but always been paranoid about popping the bead and being in the predicament of a trail fix.
Pokey71
I have always gone down to 10PSI on my cheap-o steel rims with 35's.
Havent lost a bead yet.
Hank_
I too will air down to 8-10 for sand and snow (not many rocks in Michigan) with 35's on 10" rim. Caught plenty of air and lots of wheel spin and never popped a bead (knock on wood).
Henry
rtreads
Any thoughts on pressure in deep snow??
...Funny you should ask. The last issue of 4 wheel parts magazine had an article on this.
I was saying that with snow, you can go VERY low of you follow some rules.
It says that 0-2 psi with single beadlocks and down to 4 psi with typical wheels. It had a picture of the difference between 10 and 4, and WOW there was a HUGE difference! If you do this, you need to go SLOW. If the speedo reads, you are going too fast. If you are looking to bash the snow, not crawl across then you need more pressure. You also should not do anything that will apply side load with pressure this low.
There is a snow trip that the Colorado Classic Bronco guys running on the 19th. On the last run I forgot to air down more once we hit the deep stuff. I will make sure not to forget this time. I am planning on starting at 6psi and working down. I have single beadlocks so I'll see how it goes. It will be a blast and I am super excited to try some trips from the article!!
...Have fun, and be careful!
Oh, maybe bring some spray starter fluid to rebead a tire if you need.
66horse
I typically run 8-10 in both sand and on the rocks. 35 MTRs, never popped a bead and we try to run the hardest stuff we in the places we go.
bmc69
8-10 psi is the 'magic' number I use routinely ..except when I still ran 16.5" wheels; never let them drop below 12 psi without expectin to loose a bead.
I run 5-6 psi in my IROKS..with beadlocks.
kayakersteve
kayakersteve
Western NY State
This has been very helpful - I thought I was going low at 20-25, but now know otherwise. I am going to drop down to 10-15 on my next outing and see what difference it makes. At 30 right now.
I don't think it was mentioned, but larger tires, bias ply and light weight vehicles can run lower then smaller radials on heavy rigs. Size, build and weight is also a factors. I recall a Sami running bias 42s or so, keeping the rig light he would run 0-2PSI just fine.
