Oil Leak
josimps2
I had engine oil all over the oil pan as well as the front diff and it appeared to be coming from the oil pan. I replaced the oil pan gasket and cleaned up the oil pan. However, I still have an oil leak somewhere. As I'm looking at the engine it appears to be leaking from somewhere above the oil pan on the right hand side of the engine. I know I tightened the oil filter down tight as well. Where else would this leak be coming from?
josimps2
josimps2
What do I have to do to change it? Will I have to remove the oil pan again or will this come right off and allow for me to put a new gasket on?
Carl
Aurora, IL
Try cleaning the oil off. Then after you run the engine for a while check too see where its coming from. When you put the gaskets on did you use RTV sealant where the gaskets meet? Did you use sealant where the aluminum timing chain cover meets the engine block?
Carl
Aurora, IL
If its the oil pressure sender or the extension that is leaking, then no you don't need to remove the oil pan. Its on the drivers side of the engine near the front.
stlkikn
I second the fuel pump leak.
It will either be from the gasket to the timing cover, or from the pumps bleed hole.
