Oil Gallery Plug Leak FIXED
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
351W oil gallery plug at back of block under intake manifold.
In process of rebuilding engine, installed timing set, heads, valve train, oil pump and pan.
Spin oil pump with drill motor to verify getting oil thru all push rods, and I notice a leak from this plug, looking like the oil stream coming out of each push rod.
Decide to pull deep cup plug, which involves masking block & heads, and using die grinder to remove staking.
And because the internet does not cover removal:
Drive center punch thru plug, there is room below it at the center,
Insert self tapping screw, and pull plug with crow bar,
Machine shop installed plug dry, so I decided to use Permatex #1 (hardning) sealer.
Install new plug and let it sit for 24 hours.
Spin oil pump, and it still leaks, though not as much as before.
Need recomendations:
Do I try again with new deep cup plug, and use Permatex #2 (Non-hardening) sealer, or maybe Permatex Aviation (brush on) sealer, OR SOME OTHER SEALER?
Or do I go with a disc type core plug and sealer?
The disc type expands against bore after it is bottomed out, as apposed to the cup type, that scrapes the sides all the way down, causing grooves that oil leaks past.
If I use disc type, I would be inclined to back it up with the cup type, so that it could be staked into place.
Or are there other plugs I am not aware of?
The block bore does not appear to have enough depth to thread, and at this point I would need to strip crank and cam so chips could be removed.
ksagis
Aspiring Bronco Guru
Austin
Do you think the size of an oil leak is going to materially reduce oil pressure?
i.e. it’s not preferred, but does it matter as long as the oil can drain back to pan?
I wouldn’t think this sort of leak by would degrade over life of engine.
I may get flamed…. ;)
Oldtimer
Oldtimer
Sunnyvale, CA
No flames from me, I had the same thought.
For all I know it may have leaked like this before the rebuild?
All SBFs may leak like this?
I thought about asking the machine shop, but would suspect CYA if he told me not to worry.
Maybe I will stake it and continue assembly.
Timmy390
Conway, AR
My take, it should not leak. Leaking is bleeding off oil pressure.
Now to fix it.....
From the picture with the screw through the middle of the plug, I see strike marks in the plug like it was driven in with a small socket. When I say small I mean not the correct size for that plug. Those plugs should always be driven in with a socket or driver that JUST fits inside else you run the risk of the plug deforming.
I would get a new plug and drive it in using a bigger socket. See if it leaks. If it does, I would suspect the sealing surface is marred up. In that case, I would look for the damage and use a thin (very thin) film of RTV like Ultra Gray or the Right stuff. Don't over do it with the RTV. You don't want a glob to be in the gallery
Tim
My thoughts, the staking is what deformed the seal and caused the leak.
The total failure of that plug is an issue. But a slight dribble isn't worth the effort. It still drains into the pan. Pressure drop? How much more flow do you get when bearing wear slightly?
jamesroney
Fremont, CA
Now to fix it...
Here we go:
@Oldtimer The part number on the side of your 351W block is defective. Do yourself a favor. Stop wasting time and money on any 351W block that does not say "F4TE" on the side. (I can see your link bar peeking out in the pic. So I know it's an early block.)
Don't even think of putting a disc plug under the cup plug. You need all of the surface area possible for friction to hold it in. The worst outcome is if the oil pressure pops that plug out.
If you are too far invested in this block, you'll want to counter bore the hole deeper and thread it NPT. If you don't want to do that...You can machine an interference fit cast iron slug and drive it in. There might even be enough room in that hole to o-ring it. Then secure it with a "Dutchman"
But you are making an awful lot of work for yourself. A tiny leak on an expansion plug is nothing. In fact, it is a common modification (on SBC) to drill a .030 hole in the front cup plug to keep the timing chain lubricated. (and to keep oil flowing past the last lifter...) Moreover, all of the lifters leak past their bores, all of the hydrodynamic bearings leak constantly. The entire oiling system on a SBF is just a series of leaks.
That being said...it would drive me insane to know my cup plug was leaking at that location. So you kinda gotta fix it now.
jamesroney
Fremont, CA
1. no.
2. no.
3. correct.
4. Yes, you will.
This would have to get fixed in any engine I touched. The OP won't sleep, (or eat?) if it's not fixed. It would drive me absolutely bananas to know that little time bomb was in there. It's already bugging me, and It's not even mine. Funny thing is, there's no telling how many leaks left the factory like that.
Timmy390
Conway, AR
Here we go:
X 2 Roller baby........Got mine from a E350. Total cost after part out of the van, $65 :)
Tim
73azbronco
all of them.
Oldtimer
Oldtimer
Sunnyvale, CA
Yes, I am to far invested in this block, and James, you tried to warn me.
It is a small pressure leak, and I drove this engine for years (decades) with low (15-20) oil pressure.
I have never had trouble sleeping or eating, and that is not likley to change in my 8th decade.
James, if you are have trouble sleeping, we should meet for lunch at Su's, and I will buy you a beer.
I will ignore leak and press on.
ntsqd
heratic car camper
Upper SoKA
I've been thinking about this since you first posted it, and I've not come up with a solution that doesn't involve/require a complete tear-down. Which might be a good idea anyway unless you're using aftermarket hyd roller lifters that clear the casting as-is?
James, please clarify "a dutchman"? I *think* that I know to what you're referring, but I'm not sure. If what I think it is, I'd pondered it myself but saw no way to implement w/o a tear-down.
jamesroney
Fremont, CA
I'm probably using the wrong word...but it's how I learned it...
A Dutchman is a method of securing two concentric annular members by pinning thru the interface. You can build them as a solid pin in threaded connections, or as a threaded pin (set screw). Here's a pic from the internet that was the first hit when I searched on "dutchman set screw."
Not 100% sure how or if it relates to a "Dutch Pin" which is completely different. Let me know if there is a different technical term.
ntsqd
heratic car camper
Upper SoKA
OK, not at all what I was thinking of, but I have used that method in building some production tooling. You could be using the wrong term, but I'd never know and your search result looks supporting.
I was thinking more like how some early racing engines had their core aka 'freeze' plugs pressed in, but were then barricaded with a strap across them that had two small screws tightened into blind threaded holes added to the side of the block. This was before how Ford solved it with the Boss 302 blocks......
ksagis
Austin
I'm willing to bet that this small amount of leak wasn't the source of low oil pressure and pressing on seems perfectly valid. There's a saying that comes to mind
In theory, yes, you should fix it. In practice, press on. It just won't matter!
More importantly, what is this Su's place? If it's an old dive or diner, I would love details.
Oh, it’s definitely a dive bar (without the bar) of a Mongolian barbecue/buffet in Santa Clara.
Just an old cafeteria style joint, where Oldtimer is known to occasionally hang out when he’s not working on his Bronco, or posting up great technical information here.
Occasionally joined by DirtDonk, when he’s not otherwise occupied serving the customers. 😉😁
We even adjourned to the parking lot a couple of times and crawled around the Bronco.
Before he took it all apart!
Been quite a while (far too long) since we had a Bronco powwow. Even longer since we’ve had one here at the restaurant.
Hey, party at Paul’s place!
jamesroney
Fremont, CA
You left out the part about the food. It is a restaurant. Restaurants serve food. This restaurant serves really good food.
EPB72
Pleasant Hill, CA
FWIW I have found the Dorman plugs can be hit or miss on different applications ,In the past at times would get them from the local machine shop {pioneer } was the brand at the time . they clearly had a better fittment and started better.. of course these were coolant block plugs ,, but,, found an NOS listing on ebay , not sure if the correct size but somthing to consider . 1970s 1980,s ford Engine Oil Galley Expansion Plug new nos ford 10ct 376099-S
ksagis
Austin
Really good food with a beer seems even better! And even better over Bronco talk.
ntsqd
heratic car camper
Upper SoKA
Clearly Pioneer has a lot of such plugs. Unfortunately their online info is pretty lacking in even basic dimensions.
Well, you gotta sustain your energy after all, while you’re talking Broncos!
Our other restaurant would be even better if we managed to get a big group together.
Practically in ksagis’ own backyard even, in Menlo Park. And 20 minutes closer to Andrew, so we might even be able to get BajaBronco to come out of the Northland and join us for some chow.
If James ever comes south, when he leaves home, rather than heading east into the hills, I’m not sure which one would be easier to hit. Menlo Park is just a straight shot, but you have to cross the bridge. Going to anti-commute, however, so might not be so bad.
Those 400+ parking spaces are just aching to host a bunch of Broncos.
Thanks for trying to keep the thread on track ntsqd and EPB.
Otherwise, I’d be open for a celebratory get-together when Oldtimer finishes his engine work. 😉
