Oil pan gasket replacement 1989 302
atcee
I'm dropping my pan and replacing the gasket WITHOUT JACKING THE MOTOR tomorrow. I have the black rtv permatex, cork gasket, brake cleaner, razor blades.. I sprayed the crap out of everything ( carefully) with degreaser. Gonna rinse and start early.
The guys at ADVANCE told me I couldn't use anything but the cork because I'm just going to have that 3" or so clearance. BUT I don't see why I can't snake a one piece gasket around it. WHAT products would you guys use? RTV /No RTV? Please explain well for this average mechanic. THANKS (anybody) for your help ... JOHN
jasonb
Howard City, MI
I replaced the pan gasket on my wife's 95 Mustang, and probably didn't even have 3 inches of clearance. I used the OEM 1 piece rubber and steel gasket. I am not sure if it will seal on a Bronco pan as the pan rail is not flat. Maybe someone who knows for sure will chime in. If at all possible I would use the 1 piece gasket. If you are careful you can snake the gasket down around the oil pump and pick-up, and position it in place. You also might be able to unbolt the front shocks from the radius arms, and jack up on the frame to gain more clearance, but not sure of this either. Good luck!
blubuckaroo
Grease Monkey
Ridgefield WA
RTV can't be used on cork because it is so slippery it will let the cork gasket split and squirt right out. It can end up inside the pan and plug things up really bad.
Clean the pan surfaces really well with brake cleaner so the adhesive will stick. Attach the cork gasket and rubber saddles to the pan with contact cement or weatherstrip adhesive. Don't use any sealant on the block side of the gasket. Only use the RTV in the corners where the rubber saddles meet the cork. Just a dab at each joint.
I've done too many gasket replacement like yours to remember. Take your time and it'll work.
Can't you disconnect the track bar for more clearance?
blubuckaroo
Grease Monkey
Ridgefield WA
I just re-read your post. Are you trying to replace the gasket without taking the pan completely out? That would be pretty difficult and you'd miss the opportunity to clean the pan and pick-up screen. You'll probably get a lot of crap into the pan too.
You need to lift the car with a jack under the axle and support the frame with jack stands, you can drop the axle down with the jack. I usually disconnect the track bar and shocks to get it to drop further. Just be careful you don't overextend the brake hose.
Then while the pan is out, use contact cement to attach the cork pieces and rubber saddles to the pan. The pan now can be maneuvered into place without having the gasket pieces slip out of place.
68rockcrawler
One thing I would point out if you have never done an oil pan gasket is to make sure you get the tabs on the gasket at the back of the engine into the holes in the bottom of the engine. You will see what I mean when you look at the new gasket.
baddad457
Felpro makes two one piece gaskets, one for the newer pans, one for the older pans. To the OP: The year of the block is moot, the gasket needs to match the pan.
baddad457
I'd recommend the rubber 1-piece gasket regardless of how it's done.
X2 on this. The one piece is a cinch to install on the engine in the vehicle. It comes with installation studs that make all the difference in the world in getting the gasket in th ecorrect position.
