oil pressure dropping
ca1a73
would bad valve stem seals cause my oil pressure to drop? Im blowing oil out my exhaust, burning a quart ever 100 miles or so. tail pipes are black at the ends.<br>Thanks, and suggestions would be helpful....Should i drop another motor in?
74bronc
No, valve seals have nothing to do with oil pressure. They are not a part of the pressurized oil system. If you have burning oil, it can be either valve seals or piston rings or both. Black in the exhaust pipes is a rich mixture. Black exhaust=too much fuel Blue/White exhaust=burning oil<br><br>Time for a new engine I'm afraid.
If you are burning a quart every 100 miles, It's not a matter of engine tune, it is a shot motor. Burning that much oil is likely to leave soot in the tail pipe.<br><br>The black = rich is for exhaust smoke, not soot deposits. You are probably leaving a small cloud of blue/gray smoke.
C
ca1a73
Yes it looks like the blue grey smoke your talking about. Its pretty bad when i start it up, then it goes away, but you can see it at night in the light. I have been driving it about once a week, seems to be running ok, other than the slight nocking from losing oil pressure. Should i just keep adding oil to it, while i build another motor? Could there be another fix, other than replacing the entire motor? Should i check compression? see if my rings are shot? how would i do that. Im just trying everything, other than replacing the motor....I will probably just bite the bullet and get a new one.
you could check compression and stuff, but why? It's dead. Sounds like everything is shot. puff of smoke at start up, valve guides. Smoke while running, rings. Knocking while running, bearings. <br><br>I wouldn't even wast my time trying to rebuild it, just find/build a replacement engine. after you take it out, it might be fun to tear it apart for laughs. you might be amazed that something that bad still runs as good as it did.<br><br>the first engine I tried to do had .040 taper, 7 cracked pistons (very common small block ford item), and a broken #2 main bearing cap. everyone was amazed that it still ran.
