ntsqd
heratic car camper
I'm not getting the idea that the failure mode is understood. It's not if it will fail, it is when. If the vehicle isn't used hard then the when will be a long ways out there but its still going to happen. Some add a second sensor or switch to the end of the extension and that will shorten the time to failure immensely. It's just a terribly bad idea. I'll guess that Ford only did it that way because Accounting (McNamara?) required it as the least costly option.
I still don't and won't do it that way. I move the sender to a remote mounted fitting and use an 1/8" copper tube with a coiled strain relief to connect it. I've used the copper tubing for 30+ years without a problem. GM started using it in 1973 for the oil pressure gauges in their pick-ups. Must be literally billions of cumulative miles on those and it's rare to hear of one failing. They only stopped doing it that way when the TBI trucks came along.
If you're still squeamish about the copper tubing then use -2 or -3 AN braided SS hose instead.
