you could check compression and stuff, but why? It's dead. Sounds like everything is shot. puff of smoke at start up, valve guides. Smoke while running, rings. Knocking while running, bearings. <br><br>I wouldn't even wast my time trying to rebuild it, just find/build a replacement engine. after you take it out, it might be fun to tear it apart for laughs. you might be amazed that something that bad still runs as good as it did.<br><br>the first engine I tried to do had .040 taper, 7 cracked pistons (very common small block ford item), and a broken #2 main bearing cap. everyone was amazed that it still ran.
