Superunknown
I have to do something about my old rusty calipers....
Can they be rebuilt?
Can I upgrade?
Can I upgrade?
Can I upgrade?
Which calipers?
If you have original Ford disk calipers the T-bird/Lincoln/ Full size caliper should bolt on, and has a larger piston.
Might have steel pistons? if so they're worth rebuilding.....its really easy. The ones you buy will most likely have phenolic pistons which I personally don't like/have had a tendency to stick.
Which calipers?
Original 76-77 disk calipers?
Chevy swap?
Usually easiest to just get rebuilt calipers, but you can get a seal kit and rebuild them yourself.
Do the T-bird/Lincon calipers fit in the stock suport? ?:?
