yea so i was looking at the h block or trying to and i realized the window for messing with that switch has come and gone. lol. headers and everything else is in the way. so i dont really need it anyways.
If the H-block is still there and the switch intact, you're saying you can't even get in there to plug in the new harness?
The Painless harness comes with (at least I thought it did) a new 2-wire connector already installed on that circuit. Isn't that the case with yours?
Or are the two wires just loose and unterminated?
question is do i need to connect the two wires in the harness? or just make sure they dont connect to anything? ive already tied the other end to the trouble light on the dash.
Since you already have it connected to the lamp, and presumably the wire to the ignition switch Prove Out connector as well? Are you just running the H-block, or do you have a combination/proportioning valve plumbed into the system somewhere as well?
At this point I see you have two or three options.
1. If the new harness does indeed pre-terminate the wires with a proper connector, you can somehow reach in there through the headers and other plumbing and snap the connector to the switch. This way you have a fully functioning safety circuit.
2. If no-go on the switch, you can twist the two wires together to complete the circuit so the lamp comes on for testing only. Probably not worth the trouble since you would defeat the purpose of the circuit.
3. If you have a 1-wire switch somewhere else such as in a separate combination valve, you can twist the two to the one and still have a functioning system.
4. You can, as discussed already, simply tuck them out of the way and ignore them.
5. My Plan-B if not using the switch, or even if still using it, would be to add a new switch to your parking brake pedal and use the lamp as a warning light to indicate the parking brake is applied. The switch would ground the circuit anytime the parking brake is applied.
Plan-A would be to continue to try to get the connector on to that existing switch and have a working safety device AND make a secondary branch to a new switch on the parking brake pedal.
This would presume that your safety imbalance switch is in fact working and not just stuck in the CLOSED position of course. Which would leave the light on the dash illuminated at all times!
Good luck.
