- Oct 14, 2004
- 5,001
Planning a refresh on my 73 this spring, part of that includes reworking the dash using a new dash overlay. I'm tired of all the aluminum look (since 2005) and plan on having it all Forest Green, which is the color of the Bronco and everything else black. I have a new ididit steering column that will be going in that has the Hazzard or flashers built in. I'm removing the heater and everything associated with it. Never gets driven in dead of winter, even if it did with no doors or top not much good anyway. Pretty much a mild+ trail rig. The piece labeled Holley Base is the arm that my Holley EFI monitor is on, You can see it in the last pic. Intent is mount it and aim the monitor above the steering column where my tach is now. A lot of the gauges are redundant but I already have them and I like still having the analog gauges. the only gauge I didn't have was the speedometer. Using the old plastic column cover for layout, will be using a black billet cover but its currently on backorder. Keeping the ignition switch but everything else will be rocker switches. I'm hoping to cut holes for the switches and not use the mounting plates, but I made my templates using the dimensions of the plates in case I screw up and have to use them. I want the switches in groups slightly spaced apart rather than all tight together.
I like the layout with the speedo and tach both to the left of the steering wheel...BUT, I've never seen another one like that in all my searching so wondering if I'm missing something????
I did a 2nd layout with the speedo left and the tach right just in case but I'm not in love with the look on the drivers sde of the steering wheel.
Thoughts opinions welcome. My templates are as accurate as possible cutting them by hand with scissors but everything is laid out by eyeballing so I know there will be some tweaking. I did measure and mark a line where the Tuffy glove box comes to.
