Fellas -
I'm ready to upgrade the 28 spline small bearing 9" and wanted to check to see if I was on the right track.
Intended use of this '69 Bronco is on and off road, but it won't be a hard core rock crawler. Tires are currently 32 x 11.5 x 15. Plan to add a fairly stout 347 in the not-too-distant future. Trans is currently stock 3 speed, but upgrading to an NP435. Upgrading the front diff to a Dana 44 as well. Plan to keep 1310 u joints.
I'm trying to stay on somewhat of a budget.
I know I don't want a spool or a mini-spool, but is there a consensus on Detroit Locker versus aftermarket clutch style unit versus TrueTrac type units?
-I can try to source a good used 9" nodular case, buy a used NASCAR Detroit Locker from eBay, use my current 3.50 gears, and assemble it and set it up myself.
-I can try my luck with a used one like this one on eBay - https://www.ebay.com/itm/224508623386?epid=1117847662&hash=item3445c1ba1a:g:av8AAOSwl9Jg09Qm
-I can buy a new setup from Speedway with a gear-style differential (similar to Detroit TrueTrac, I believe) for $1,069. https://www.speedwaymotors.com/Ford...ifferential-Premium-Third-Members,406880.html
-Currie sells a nice one, but it's spendy at $1700 - https://www.ebay.com/itm/264968422681?hash=item3db1594519:g:D-8AAOSwQj9eD3Pr
