Slim
Lots of folks running the NV4500 as well. I've had both. Utlimately, I wanted better gearing for off-road and highway, which I get with the 4500. Otherwise, 2-4th gear are nearly identical to the stock 3spd (which is good and bad)...some people like that and some dont. The 2nd, 3rd gear of the 3550 are nice for around town...and the 4:1 1st gear makes for a great launch. The 3550 shifts a little smoother, has a sportier feel...in that respect.
However, depending on which tranny shop you talk to, you will hear some horror stories about the 3550 as far as durability. I was unimpressed with the bearings (nylon races)...but the countershaft is substantial--much beefier than an AX15 (side by side). Its a fine swap, especially for a DD. If you do ever plan to crawl, the 4:1 1st gear is an improvement over a 3spd, but cannot touch the 5.6:1 of a NV4500 or ZF. The NV4500 is a much stronger unit but between its ratios and its longer throws, it feels more like a truck gear box. You can get good shifts from 2nd--->3rd and 3rd--->4th, which is where it counts, but its not a drag-racing tranny by any means. The gain is Crawl ratio=finesse=greater stability which means the rubber stays down...ideally...at least that was my thought process. As well, with the 4500 you can gear a little deeper since you have a deeper OD. Cost difference between the two is fairly minimal, a few dollars more for the NV4500 tranny. As well, the "kit" doesnt come with the cross-member (like with the 3550--which is stupid), so there is an extra $100 there, unless you build your own. Additionally, with the 4500 you will need to shorten/lengthen drivelines, so there are a few extra $$ there too.
Thanks 'psycho. That is some good info I didn't know about. Good to learn something new everyday.
