Original or recovered seats?
Cody_T
I have been debating redoing the interior, but if these are original I will likely keep it as is.
Any help determining if the seats are original or reupholstered? Also what about carpet, is there a way to tell if it had carpet and what color it was?
I’ve looked all over and it seems some are textured looking. And other are smooth vinyl.
Also mine seem to be all the light white and mine are darker in the texture.
Thanks for any help.
Scoop
Bronco Old Fart
Cuchara, CO
They look original style - correct rosette inserts. What year? How many miles? The pleats were horizontal or vertical in different years. If they are original, they are in very good shape. Too good of shape if your Bronco has a lot of miles. The missing arm rests make me think they have been reupholstered. But as stated, original style. I would not replace them unless you are looking to change the color or style.
Carpeting looks aftermarket to me. Is the Bronco any special style? (Sport? Explorer?) Parchment seats usually came in the base Bronco with vinyl mats front and rear.
C
Cody_T
It’s a 74 sport, odometer is at 58k, and I believe it’s the original 302 but didn’t check numbers yet.
It was repainted at one point, I would estimate 20 years ago based on the 2 previous owners that I know. Not sure if the seats were covered or not.
I would suspect carpet was changed, looks newer. I just didn’t know if the color was correct.
Slowleak
Georgia
Those are not original seat covers. The inserts are a darker color than the rest of the seat and there is also a seam in the lower section of the rear seat cushion. Original covers did not have that seam and the inserts matched the rest of the seat. Also, it would not have come with carpet unless it was a Ranger and Rangers were not “Sports”. A ‘74 Sport would have come with parchment mats.
C
Cody_T
Thanks for the info. I’m really clueless when it comes to originality in these things, and I didn’t want to modify original equipment if it was still here after 48 years.
When I got under the seats I saw the old burlap. It seems to have original floors as well, but I suspect they were painted over at one point. The underside was painted but appears to still have factory looking spot welds but I’m not an expert on that.
I guess I should of titled this “what’s original”
Rustytruck
burlap under the seats are not original it would have had interwoven wire mats oner the springs at least my 1974 did,
okie4570
NW OK
Yes and 34 isn't a Ranger seat code as well.
And even when they came with carpet, I don't think they would have used black carpet especially with a green Bronco.
In fact, I can't remember ever seeing a black carpeted Bronco from the factory with any body color. Anyone know if black was a factory color? Likely with a black Bronco i would assume, but not many other colors i would not think.
