- Aug 23, 2007
- 24,448
I finally got tired of my externally lubed transfer case and inconsistently shifting C4. I built up my spares over the last couple of months. The new tcase was originally a T-shift that I converted to a J-shift for the lower gearing.
The new C4 came from a '73 and it needed more than a few parts to get it back in working order. The forward clutch was fried and the front planetary gear was seized. Luckily I also had a parts C4 with some good planet gears. I drilled the rear of the case to provide oiling to the #9 thrust washer, modified the stator support for full flow to the external cooler, installed 5 Raybestos frictions in both clutch packs and installed a Transgo reprogramming kit. I also paid particular attention to the clutch pack clearance and used some selective snap rings to make them perfect. It should be good and strong and hopefully last longer than the 60K miles I got out of the old C4 stock rebuild. Total cost was about $350 for all the good parts.
The only thing noteworthy about the new D20 is that the speedo drive gear has one less tooth than the old D20, so I need to come up with a new driven gear now. Ironically the one I need is the same one I had before I changed to 4.10 gears and I can't find the old one now.
