- Aug 14, 2018
- 647
ok. I am building this 71 with basically all new parts. the door and latch work and close perfectly. when I use the inside latch it works fine. now that I have the outside handle on, it requires a LOT of thumb pressure to open. I can open it fine, but my daughter can't open it even with both hands. the rod seems to be adjusted fine, but for some reason it just pushes really hard. if you remove the rod the button itself moves freely, I am at a loss to see a way to fix this. it is not a huge problem as I said I can open it fine. but I know there is no way my wife will be able to open it. I guess it is a good anti theft device but I would like to find a way to address it. any help?
