P/S pump clarification.... Please
Broncotj0
Mankato, MN
I'm about to dig into my explorer 5.0 swap and have been looking at p/s pump options. I currently run a sag single return unit along with ram assist and hydro boost brakes. In the research that I have done I have seen the terms "tc" and "p" style pumps being used. Can anyone explain these pumps to me? Thanks
sykanr0ng
Some here have had success with the stock Explorer PS pump, others have used Super Duty PS pump internals in the Explorer housing.
One thing I would recommend and will be doing myself is to use a bigger PS fluid reservoir, the stock one from the Explorer does not hold enough for our uses (bigger tires, hydroboost,.....).
Broncotj0
Broncotj0
Mankato, MN
I guess I built this thread a little premature. If I understand correctly the tc is a remote reservoir unit and the P is the standard "can ham" sag pump. I do know they make different versions of the can ham with different output ratings. Along with having units that have dual returns.
I currently have a sag pump with an extension tube to allow for more fluid compacity along with a cooler.
I have no desire to run the exploder p/s pump and I don't want an external reservoir.
C Saporito
512cadillac
saginaw pump
Not trying to change the subject but I thought one of the bronco parts suppliers offered a bracket to use the Saginaw pump with the explorer front end. It wasn't very expensive and would give you the best of both options. Just my thoughts, hope it might help.
Broncotj0
Broncotj0
Mankato, MN
Thanks saporito! Cadi I believe wildhorses does. What i really would like to end up with is to keep both my pump and York. The only reason I'm looking into options is my pump just started leaking like crazy. I know the seal kit is cheap. Just hope my pressure and flow mods aren't what caused the leak. It's been on for five of six years now.
