painless and holley sniper
golfobx
Suffolk, Va
going to be installing the holley sniper this weekend...and i have the painless harness...
wondering if there is anything special here...seems pretty straight forward but figured id ask in advance...
Rocking Bronc66
Its pretty easy, most important thing is to make sure the main power and ground are hooked directly to the battery and the pink wire is hooked to a clean 12v source that gets power while cranking... i had mine done in a couple of hours.
The hardest part is trying to hide the sniper wiring they have several large connectors just a couple feet from the tbi unit.
eric0o1
use the #954 white/black wire that would have powered the electric choke since you no longer have need for a choke wire. All wires on the switched 12v side of the fuse block will be "hot" while cranking, so any of the orange or pink accessory wires will also work.
