Working on 1973 engine compartment wiring. Two questions.
1 - as seen below, I had the Duraspark II ignition module mounted on the front of the passenger inner fender. The ignition module wiring from Painless is all coming from the center grommet. I’m thinking of rerouting the wires thru the passenger side grommet. Where do you all put your ign module and what do you suggest for wire routing?
2 - Painless supplies a Safety Switch circuit, supposed to go onto a neutral trans or clutch switch, which I’m not going to have on my T-19 trans. I assume I’m going to need to switch or connect those wires together in order to start. Does anybody hide a switch for that purpose?
Thx!
Thx!
