Paint matching?
kip60
Would like to get a little more mileage out of original paint. Needing rockers like all projects do. Wondering if anyone has matched up 1970 code D Pinto Yellow in a rattle can? Just wanting something close so it's not yellow and black or primer.
wesleydax
my ppg store can mix automotive paint and put it in a spray can. Its a little high at 20.00 a can but worth it. he can even shoot a proffit and mix to that so to take in the years of fading
sykanr0ng
You also can buy or make a refillable spray can and put the paint into it.
Cheaper than buying one they make for you.
lsukevinc
Holly Springs
thanks 1000 times. I have an area on my tailgate that needs to be repainted and I was quoted $200 for a side job. I called a PPG store which happened to be 5 minutes and for $60 I can get two rattle can mixed and one can of clear matched to my existing color.
JT3357
Did you have any luck getting it matched? I had my local O'Reilly's mix up some Pinto Yellow touch up for my 1970.
Whoaa
yes, they mixed it and I picked it up maybe an hour later. I have not sprayed it yet.
It would really be nice if you can take some before & after pic's and comparision pic's and then post them here, thanks!
Lawndart
I had a good local auto paint store match my original burnt orange paint. They took the paint code and then added some matting agent to match my paint condition.
Here is a shot of the result - I added new flares which I prepped with the new paint. I think they turned out well.
jbawall
Edgewood, Washington
What about matching a non stock paint color? My PO had it sprayed and I have no idea what color code it is. Can they do the same for that some where?
allenfahey
All good paint jobbers have a color eye. They polish a flat surface and take three "pictures" and you get a paint formula. It will sometimes give you a good match and other times it won't even give a blendable match. Even if you have a good paint code and a good hit with the camera you will still need to blend into the adjacent panel. Depending on the color it is nearly impossible to get a 100% color match. For that reason we always blend into the adjacent panel. For example if the repair is near the door handle you would need to blend into the front of the door and the 1/4 panel to trick your eyes into matching the paint. You only apply paint to the repair and spray the blend in a "/" pattern in the door and a "\" pattern in the 1/4. You do not apply color to the whole panel! After the base flashes you clear the entire panel. Some colors are harder to blend than others but it's pretty easy. Make sure to sand the blend with 800 or finer and a grey scuff pad.
Probably more info than you asked for but just a FYI
One more thing... if you can find a Spies (owned by Axalta which used to be Dupont) jobber, they have an awesome new color eye. I forgot what they named it but it is by far the best one I've used. When I sprayed Spies water I never looked up the paint code, I just used the camera which gave me a great blendable match 99% of the time. Found it. Acquire EFX Plus
lsukevinc
Holly Springs
here is the spray paint my local ppg mixed up for me. I gave them the paint code from when the bronco was painted 8 years ago. I should have had them lighten it up a little to match the fading, but it is hardly noticeable.
