i am new to the board but have had my '73 bronco 25 years. it has sat the last 13 and after several thousand dollars and 3 months it is up and running. however, i continue to have battery drain. when i connect a meter between the negative cable and post i have 13ish volts. if i unplug the voltage regulator or disconnect the alternator, it is gone. i have a new vr, new alternator, solonoid, ignition switch, headlight switch, battery (motor, trans, rears, etc). the wiring harness is original, although i made some new connections here and there. i have double and triple checked the wiring, and replaced the voltage regulator three times and the alternator twice. all the alternators have bench tested ok, and i am getting full charge while the engine is running (meter on the battery 14.5ish volts). look forward to your suggestions. thanks i will post pics and more info when i figure out how. thanks
