Parking Brake Not Engaging
mj2619
Any idea what I need to do to fix this and getting the parking brake working? Thank you!
  • IMG_4671.mov
    3.3 MB
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
The parking brake pedal does not seem to have a return spring. It should slam up when you pull the release lever.
serial car restorer
Yes, I'll restore almost anything...
Western Oregon
Pedal should not have a return spring, the springs are part of the 2 rear cables. I'm also questioning the length of the threaded rod. The cables should be adjusted to be barely snug, no slack.
mj2619
mj2619
Thank you! Struggling to understand on my set up (1977) where does the return spring attach to?
1969miller
Elk Grove
On the more common setup, the spring hooks into the equalizer lever and then hooks to the frame. on the threaded rod/cable setup, it hooked to the end of a hole that was drilled into the cable, then either hooked to the frame or to a body crossmember. I dont have any broncos here with that setup. There are springs on the ends of the cables in the drums that should release the pedal without an external return spring when the whole setup is properly set up with minimal slack.
Oldtimer
Sunnyvale, CA
mj2619,
Spring may of gone in hole that has cross bolt in it?
77 Bronco would of had a 8-1/8" long spring,
Similar to this 76 F250 4x4.
Need someone to post a picture of stock 77 assembly.
mj2619
mj2619
Made it work...need to clamp the extension lines. Thoughts?
stretch
Montgomery, TX
Ordered these a couple of weeks ago from Tom’s. The brackets arrives but not the cable extenders. No explanation. Called Tom’s. Cables are on back order, no eta.
