Parts list for Explorer Serp Swap (hoses/belt/etc)
Tiko433
I know just enough to be dangerous
South West Florida
Good thread guys! Great info . Are you removing the AC compressor ? If so do you just run a shorter serpentine belt ?
kat
kat
Bristol
I know this might be a dumb question, but if I use my 45 degree thermostat housing I wont be able to use the GTO Upper radiator hose right??..if so what do I need to look for the get a 90 degree housing??
toddz69
You *might* be able to use it - would require a twist at the thermostat housing to fit.
Late model 5.0s - Mustangs, Explorers, etc. use the 90 deg. housings. The Explorer ones are a little shorter for front dress clearance. I'd have to check in my parts box - I might have a decent used one if you're interested.
Todd Z.
kat
kat
Bristol
Todd Z.
Thanks...Ill go back to the junkyard and look at the Merc I took everything else off and see if it has one.....
73azbronco
Duff makes an extended bracket for the lower radiator mounts, but it's for 2 inch body lift.
It would get you closer or maybe modify them or you could take the idea and make a three inch.
http://www.dufftuff.com/product_p/3111.htm
Interesting and have not seen this as an option, why do i want to lower my radiator? More interesting, can I build a 4 core that is 2 inches longer giving me more cooling?
sykanr0ng
The body is lifted which raises the radiator and fan shroud since they mount to the core support.
The engine is not raised so the fan is still where it was before, now three* inches low in relation to the radiator and the 'hole' in the fan shroud.
Lowering the radiator brings it back in line.
* or however high the body lift.
73azbronco
Sounds reasonable, anybody consider making a taller radiator to boot?
kat
kat
Bristol
Updated the OP. After 3 trips to the parts store ended up with a 8750k6 (87 and 1/2 inches) serpentine belt (without A/C). Evidently the Driven 4x4 pulley is a different diameter.
