PCV valve question----- problem seems to be solved
Gerbow
Jacksonville
Should oil be coming thru thru the pcv valve and into the hose? Its not alot, just noticed some there when I removed the hose to install a new one.
Also, I guess if the above answer is yes, will that oil cause smoke to come out the exhaust?
There will be some oil vapors and that will make the inside of the hose oiled. But to the extent that it is oiled? If it is pulling too spray, baffle missing, then it can pull signifient amounts of oil. It could be the rings are shot. Leave the PCV out of the valve cover and go for a quick drive. Other then some oil spray out the uncapped hole it could be a quick test to see if the engine still smokes.
Gerbow
Gerbow
Jacksonville
I'll try that in morning. It doesnt smoke much. It looks white to me, but I only see t once on awhile when the wind may blow it in sight. It never smokes when I stop and.get out to look at it though. A friend behind me on the road yesterday said he thought he saw blue smoke when I would give it a heavy foot. I didnt get around to checking my tranny modulator today. And I stopped at a mechanic to see about a rebuild or whatever is needed if this turned out to be major and he said doesnt seem to be anything wrong except it may be running rich.
Anyways, BB, you answered my question. I'll do that other check 2moro and the modulator.
All this said, I DO go thru some oil now... Little bit leaks, but nothing really marks up my driveway.
My tranny fluid was a little low so I thought modulator.
Just trying the cheapest things first.
Gerbow
Gerbow
Jacksonville
New PCV valve....went from about a qt of oil every fill up (both tamks) to now on my 2nd fill up and not even half qt low. All the money Im gonna save on oil now, 1st rounds on me tonite!!!:)
