Pedal height
dwiriea
My clutch pedal sticks way out past the brake pedal (clutch 9 inches out and brake 6 inches) and the gas pedal sticks out out farther than the brake (around 7 inches). It just doesn't seem right.
Should the clutch, brake and gas pedal be at the same height, or should the clutch and brake be the same and the gas pedal a little lower than the brake?
I know how the brake and gas pedal are adjusted, but I can't see any way to adjust the clutch pedal other than to relocate the rubber stop. Am I missing how the clutch height is adjusted?
Thanks,
Dale
recoiljunky
Dothan, AL. USA
The brake and the gas pedal should be the same height so that your right foot only has to move laterally.
Typically, you have to lift your whole leg up to reach a mechanical clutch.
My bet would be that your brake pedal is a little low. Someone else with more knowledge will chime in shortly.
