Petronix Performance Kit
cody72sport
my petronix just failed, replaced with an hei distributor. My bronco is running better than it ever did with the ignitor.
Which brand did you go with?
Most people really like the way they run. It's the reliability that's been hit-or-miss. But the good news on that is that lately at least, there have been fewer and fewer complaints about failed HEI's.
Maybe even the cheap companies have been getting their act together.
rubywoofs
rubywoofs
Southlake
Well, I'm almost done. Now I'm working on connecting my new wire to the ignition switch. I can't see how to get the old resistor wire out of the black strain relief piece so I can run my new wire in there. Does it come out, or am I trying to splice, or am I missing something?
rubywoofs
rubywoofs
Southlake
Here's a photo of my switch wiring. Looks like the resistor and other wire are bound together.
That's a good pic for our archive, thanks!
So that's how they did it in '74 then. First time I've seen the two wires together all the way down to the connector.
As far as pulling the connector out of the strain relief, turn it over and you should see a little spot where you can shove a tiny screw-driver or poker-thingy to release a lock pin. When you do this the copper connector should pull right out.
It's possible that the slot you see on this side is the same slot on the other side that you can push the release tool into.
Is that a Green w/red wire next to it? Or a Red w/green? Let me look at a '74 diagram to see if I can determine exactly what it is. You might be able to avoid all this just by cutting and splicing into that wire instead of the resistor wire.
Resistor wires are not good candidates for crimps themselves, and pulling the wires out of the connector can be a pain. Be much easier if you can simply splice into the existing normal wire and just ignore the resistor wire altogether.
Ok, looks like you can splice right into the Green w/red wire. Unless you'd rather de-crimp the connector and start fresh. But I don't see that as necessary.
Splice into the Green w/red so that it still does it's normal duties, but branches off to power the ignition as well.
It's just coming from the same connector as usual and the Green w/red runs off to power the voltage regulator, brake warning lamp, emissions solenoid, and probably a few other things as well.
The Red w/green is for the ignition only, but yours starts off as the resistor wire instead of normal wire, so you need to work with the Green w/red instead.
I would recommend a 14ga wire, but maybe others will have a different recommendation.
Clean up those contacts the best you can too, to make sure everything has a good connection and will last a long time without building up excess heat that can cause trouble down the road.
rubywoofs
rubywoofs
Southlake
Great. I can do that.
So, do I just cut the resistor at the switch, or leave it alone?
Again, I really appreciate your help. This was obviously not plug and play for me. Could not have done it without your help.
I have to admit, I got slightly too big wire (12 gauge) for my new wire and it wouldn't fit into a crimped fitting that came with the coil. I went old school and curled a striped section around the post of the coil and clamped it down with the nut. I'm sure that's not ideal, but is it a big problem, or just not great?
I would just leave it. You never know when you might need it (probably never) and at this point there's just no need.
Besides, you actually can use it for something else in the future, with the help of a relay. You can use the resistor wire to trigger the relay and let the relay feed a full 12v to whatever you want to power.
It's never a bad thing to have extra wires on a Bronco!
Yeah, 12ga is pretty healthy. There are some uses for it on some projects, but most can be done with 14 or less.
But you can always get a larger connector (usually with a Yellow insulator).
I went old school and curled a stripped section around the post of the coil and clamped it down with the nut. I'm sure that's not ideal, but is it a big problem, or just not great?
Not a big problem (yet) and yes, it's not great.
Plenty of reasons to put a real connector on it when you have the chance, but nothing says you can't run it that way for now.
Really though, this is the kind of thing that many times turns into a "it's temporary, unless it works" kind of thing and then gets left that way. But I would fix it as soon as you can.
But it should work for now!
rubywoofs
rubywoofs
Southlake
WOOHOO!!! I finally wrapped it up. I thought getting the ignition switch back in was going to kill me, though.
Anyway, got everything buttoned up and crossed my fingers. Turned the key and, after sitting for a few days (normally a tough start), she fired up instantly. Neighborhood spin also gives me hope that there's a little more power and smoother running, too.
Thanks again Donk. Your help was critical and awesome.
Hey fantastic! Long way down that tunnel to the light. Hopefully it's the light of day and not that famous headlight of the train coming your way!:eek:
Good luck. Now what's next?;)
