picking a cam & other upgrades, '94 351W Lightning eng. in '69 EB w/ Mustang A9P MAF
I'm sorting out which cam to get, and what other upgrades to do engine wise at the same time and I'm looking for a concensus of opinion.
I have a complete 94 Lightning engine ONLY, that I'm going to install in my EB. I have already stripped off all the smog crap(Thermactor, Smog Pump, etc), all the stock Lightning Speed Density crap, and some other crap that I'm not using(front accessory package(Alt, PS Pump, AC Comp, etc)). I'm going to run the engine with a modified Mustang(89-93) harness, and most likely an A9P Mustang ECU. Since that vintage Mustang setup is Mass Air Flow, I have some leniency in setting up the engine. I spoke to Ford Motorsports, and they 100% recommended using the 5.0 Mustang 89-93 electronics. They also suggested their 12071-A50 stand alone SBF EFI harness, but at $650, I decided to look into other options, RK harness.
Due to space constraints, I'm using an Explorer 5.0 serp front accessory package. Since I have to swap out the timing cover anyway, and since I'm pulling the intake to clean it up, I figured what better time to make a cam swap, and at least get a roller cam into this thing. I have an F4TE block, so according to what I read it should be roller capable.
Other than the cam, lifters, spider, "dog bones", & new pushrods....anything else I would need to convert to roller?
I was thinking new cam and lifters, but if the right one comes along for the right price and has very little use, I'd consider used too. With a roller cam & lifters, does it matter as much if it's used like it does with a flat tappet cam?
I've had a few people mention the Trick Flow Stage 1 cam. What about the Stage 2 cam is too radical for the stock GT40 heads I have? Would GT40P heads be a better choice?
Given what I'm planning to use the Early Bronco for, I'd like to see both HP & TQ over 300. Will the Trick Flow Stage 1 get me there, or do I need to step up another notch? Anything else I should do at the same time to get the HP/TQ #'s I'm after? This is the important question to me....anything else I should do before dropping the engine in the EB? Since I have it on a stand, any other modifications to make are easy right now. I'd prefer to set this up correctly the first time around.
I'm considering eliminating the EGR valve and spacer at the TB that it mounts to as this may allow me to keep the intake turned the correct way and still clear my PB booster/bracket. Is there any good reason NOT to eliminate the EGR? If I turn the intake around to face the pass. side I then have a conflict with the upper intake hitting the fuel pressure regulator and not seating down all the way. I've also considered taking the heads off and freshening them up, but then I'm starting down the road of, is it just better to buy aftermarket heads vs. dumping $$$ into factory heads. I could get a set of P's for not too much and freshen those up as well. I know about the whole spark plug angle conflict with them. Someone mentioned in the past that the P's have a smaller chamber which would help with bumping C/R up a bit.
I'm not sure if I'm going to use the factory Lightning shorties, the Thorley long tubes currently on the Early Bronco w/ 302, or something else.
I'm all ears.
P.S. If there are any stock Lightning parts you are after, I might have them for sale. I'm willing to trade these parts for anything I'm looking for...Roller Cam(TF, Comp or other mfg), Roller conversion parts, anything else interesting that would help with my build.
I'm all ears.
