Will this be on your 4 door one? The biggest issue I can think of with it will be the door frames. On PDXBronoc's it was easy because his is just 12" longer in the tub. If we can figure out the exact difference to make the door frames work on yours then it can probably be done. May want to substitute a heavier piece over the doors for some extra strength but it will depend on how it needs to be made.Kinda hard to make a top for a truck that isn't right in front of you. I think Rick is offering up the right way. Let him see it and make the adjustments he sees needed. As a first fitment I think it is fine, not as a final product and that rollbar should be 2" above the windshield line.
I think Rick will have agood time when I commision him to make mine w/ a halfcab back panel. He's gonna earn his pay on that one. Might have to fly him down here to do it though.;D
I would try it on a Buddies Bronco with a different roll bar.
From these pictures, it looks like your bar tappers in more than most (although I was wrong on how high it sat).... which in turn, would not support the rear.... causing the flaps to look like they do.... Just a guess
Saddleup,
Reference your comment #19. Perhaps I did get it right about the door frame interference?
Beach Bronco
looks to me like the door shuts....%)
I could be seeing things though;D
Saddleup,
Beach Bronco
Tom, I'll get back with you on the measurements etc. so we can change it to work better on yours. I need to remake both of them as the other one also doesn't come tight in the middle either.......................
How are most bikini tops mounted in the front at the window frame? slide bead?, Velcro?, snaps?, straps?
Now that's service! What are you asking for a White Bikini, if I may ask?
