Got a full image of it? Do you have another arm to compare to?
I've got pics of some known Bronco arms and will post them up in a bit, but if size and orientation are consistent with EB arms, maybe it was a "tweener" used about then?
At least as far as the old books are concerned though, that is not a Bronco pitman arm.
Not a full-size truck arm either for that matter, unless it was a running change that got missed in a certain addition of the parts files in both print and micro-fiche form maybe. I'm sure it could happen.
Maybe it was an interim arm between the fairly small-ish earlier manual steering arms, and the later beefier power steering arms?
I don't doubt Viperwolf's knowledge on this kind of stuff (and he rebuilds Bronco boxes regularly, so has stared at more pitman arms that I've seen I'm sure. But it sure does not look like the '70 arms I've seen.
But the fact that it's a "T" part is the proof that it's indeed a truck arm of some kind. Just that it's origin has faded into obscurity...
Maybe it's an upgrade right about the time they were getting ready to put stronger Dana 44's under the EB's as well. Perhaps for the same reason they were beefing up the front end. Even when the first Early Bronco books were being published, pictures of Broncos sitting with their noses in the sand with busted-in-half Dana 30's were already circulating and probably leading designers to hunt down weak links. Maybe some steering arms were busted in the making of those books...
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
But if so, it was not listed with a specific application in the Ford books. Waiting to hear back if there was a known passenger car line it was from, but not listed in the Bronco file.
From another forum source with Ford parts books and fiche:
"D0TA-3590-AA crosses to D0TZ-3590-A but it's not listed in the parts catalogs for Bronco's or trucks.
O-S-I catalog says: Obsolete, there's no replacing part number.
1966 Bronco was C6TZ-3590-C, but this was replaced by C6TZ-3304-S draglink and C6TZ-3590-J pitman arm that was used in 1967.
1968/75 Bronco was C8TZ-3590-E (M/S).
1972/75 Bronco with P/S was D3TZ-3590-A (D3TA-3590-AA).
1976/77 Bronco with M/S: D6TZ-3590-A (D6TA-3590-RA)
1976/77 Bronco with P/S: D6TZ-3590-B (D6TA-3590-SA)"
If anyone has a listing for the arm in question though, would love to see it and put it in the database.
Of course, the bottom line is that if it fits, it'll work. Do you have a draglink you can try it on for size?
Or have all your parts been finally installed, and the rest were tossed out long ago!;D
I'm sure someone can measure a rod end and find out though.
