sorry this got long but I loved these stupid things but I strongly recommend you spent your money somewhere else. They are old technology and not very strong.
The unit is a Borg Warner OD unit, quite popular in the late 50s and early 60s, before automobiles made a lot of HP and were geared low because of the lack of HP.
Not only did they make the driveshaft too short and at a steep angle, it WILL be the weak link in your drivetrain. the main shaft in those things is pretty small. I twisted one off in my 55 chevy with a 235 inline six and all I had done to it was put headers and a small 4bbl on it. I doubt they would be up to taller than stock tires or heavy HP.
My 55 chevy had a different out put shaft than stock and when I twisted it off I paid a premium. I bought everyone I could find after that at swap meets. Still have one in the barn.
Just cant bear to part with it they are really cool to drive. In town with 4:11 R&P you could start in second and the planetary in low and let it upshift and down shift as needed, the only time you use the clutch is when you come to a stop. Problem is everyone did that and it wears the transmission main bearing because it is really meant to see 3rd gear every once in a while and get a rest. Most every mainshaft I ever saw had wear in that bearing. the internet may have helped the situation but back before Al Gore invented the old interweb the only way to get parts was to buy old junk at swap meets.
There is a spring that wraps around the shaft to slow it when it shifts and it is easy to break taking it on and off and it wears. The fix is to squeeze it, problem is you might break it. That spring was impossible to find and I actually ran one I welded heated and quenched for 30,000 miles.
I did see build one time where the guy had located one of these things including a shaft that he claimed would bolt it directly to an NP435. He claimed an adapter was actually available to allow the unit to go between the transmission and transfer case. I spent a ton of time trying to find anything on the internet with no luck, other than I did find BW did make a bigger heavier unit for trucks and busses so who knows.
Just buy one of the modern planetary units that go in between the transmission and the t case. They don't add much if any length to the set up. There was a thread on here just a few days ago, I just cant find it and need to go right now.
