Saltywater
Ok, I realize these questions have already been asked and answered in the past, and believe me you, I have read them all. I'm a pretty patient man, but this thing is driving me crazy. Please help!!
Vehicle: 1976 EB, 302 V8, C-4. edelbrock intake, holley 600 carb:
Radiator (heavy duty) is two years old (and just professionally flushed), brand new thermostat, new factory type shroud, etc.. All the same stuff everyone normally replaces to fix an overheating problem. Here's my real issue as I'm sure every bronco owner has had to contend with. I only have a little over 2 inches between the water pump pulley and the radiator. To further complicate matters, I have a vintage A/C system installed and the compressor further restricts my room. I am running a fixed 6 blade (non-flex) fan. The fan is pretty rough and it looks rather dated but it is the only one I can seem to sandwich in this tiny space with a very odd spacer.
My ideas: I have not checked the timing (I don't have a light). Is there a way I can accomplish this without the timing light? Which way do you have to turn the distributor?
I believe my engine is running rich ( I have also read this may cause an EB to run hot? I don't even know where to start with the carb. I have rebuilt several old outboard motor carbs, but I have never messed with a holley.
I have considered buying a new (less restrictive and thinner) radiator, but I hate to throw good money toward one when mine is fairly new.
Also the water pump is new. Any suggestions you might have would be greatly appreciated. I have only owned the bronco for a short while and I'm really becoming frustrated with this problem. I think they should have added an extra 6 inches to the front end so you would have all the room in the world for mods.
Why in the world hasn't someone offered a custom core support designed to inset a custom radiator further forward so you could use say a mustang 5.0 shrouded electric fan? Thanks in advance everyone, I really appreciate it!!!
Saltywater
Saltywater
