Ok so I am having an electrical issue I’m out of luck with.
1973 Ford Bronco. Story goes I had an issue with the turn signal fuse always blowing. Stupid me put a larger fuse, way more than was supposed to go in there to keep it from blowing. Well went to start it and drove around and started having smoke and burnt electrical coming from under the dash. Immediately shut car off. Got her back home only to realize that the back up lights, which are also part of the turn signal switch were unplugged and were grounding out on the valve cover. The fuse held but the wiring didn’t. Now my bronco won’t turn over. All accessories work when the key is in the on position, but I can’t get it to turn.
So far i have tested the starter solenoid by jumping it, which turns the starter and starts the car, however I have no power coming in from the blue/red wire when attempting to turn the car over. I assumed it was the ignition switch, purchased a new one, still no start and no power to the red/blue wire when attempting to turn vehicle over.
I replaced the fusible link that connect to the starter relay to no avail.
I have an MSD ignition so no ICM, so I don’t think there would be any diagnosis there.
im wondering, is there two Separate power sources at the ignition switch, one that powers accessories, which all work, and a separate circuit dedicated gage the starter relay?
I have looked at the wiring diagrams and see a yellow wire that seems to power the ifnition switch?
I have looked at the wiring diagrams and am wondering if I fried wiring at the ammeter behind the cluster?
Any help would be appreciated. I am at a loss, the usual culprits seem to be working but why no power from my ignition switch to starter relay, but power to all accessories in start position?
