Why did this happen ...this was on my Jubilee Ford tractor not my Bronco but Like my tractor a lot of our Broncos set for several month only to get started for a Sunday evening stroll ..Yesterday I started my little tractor to plow up the wifes garden ..Well after about 30 minutes of plowing it dies at the end of a row, like it had run out of gas ...Damn the luck I was almost finished..I tried every thing to get it started ...Put 4gallons of fuel in a 11 gal. tank ..pulled the fuel filter toward the carb it poured ..put the drain plug in the bottom it ran and was not trash. Put the jumper cables on the diesel tr. spun it over fast as heck...Give it a shot of either..No Go there either ..Jumped across the resistor..NOT....Pulled the dis cap rotor turns when motor spins ....Fire all the way to the points...Swapped coils ..NOT.. Swapped coil wire Not ...Had good gap in points and points only had about 15 runs on them..Plugs only have about 15 runs on them and it was not missing when running ..
...So this evening I got help to towe it into the shop ...pulled the points out the only thing I could find to file them with was my 3in die grinder I snapped the points over the disk and twisted it by hand about 20 times ..That took the green color off the points ..Put them back in it starts right up.....Now how can it be running on a good set of point for 45 minutes and die in mid stream...
...I had every thing back to 1st run except the coil wire and fileing the points I like to know what the culpret was in these times...
... How could it stop in mid stream...
