Potential EFI No Start Solution
EricLar80
So, I ran into this inadvertantly while re-arranging/cleaning up my wiring and thought I would pass it along...
I have the RJM harness and originally had the orange wire (start/crank) wire hooked up to the 'I' on the starter solenoid and everything worked perfectly (as it should).
When I cleaned up the wiring, I took the orange wire to the ignition switch to bring it under the hood, but then it would not start. The fuel pump would run when I turned the ignition on, and also seemed to be running when I was starting because I would hear it when I stoped cranking. I checked codes, everything was fine.
I decided to check spark and hooked up the remote starter to the starter solenoid, pull the trigger and (surprise!) it started and ran perfectly. Decided to try to start it from inside - nope. Remote starter - yep. Then it came to me - I had hooked the orange wire to the accessory post (center post) on the ignition and this does not supply power during cranking and, hence, my computer was not getting power.
So, long story short - hook the damned orange wire up to hot while crank/run wire!!!!
Eric
Thanks Eric. Potential issue officially avoided for those that read this.
Now... If only we'd always be able to remember what we read when it comes time to put that info to good use!
Always fun, this "learning at another's expense" thing.
E
EricLar80
Yeah, I just thought it may come up if someone searched for some key words...
Eric
