I’m in the process of doing a full drum to disc conversion on my 1974 Bronco. The conversion consists of the Chevy\Ford Disc system up front and Explorer Disc on back. My current question is what to do about my master cylinder replacement………. My initial intent was to add the F250 “Camper Special” and later go with a power assist option (current budget constraints). However, after doing some research on the pros\cons of larger bore master cylinders, I decided to see what options are out there for power assist systems. I don’t have power steering, so my only option was a regular vacuum boost system. After doing some searching. I found what looks like a pretty good deal on CJ Pony Parts. It’s a complete new system (minus a new proportioning valve), but states it’s only designed for Disc\Drum setups. The price is $269 (with the 10% coupon) and free shipping to boot. With other systems for Disc\Disc specific setups, $100-$250 more, my question is as follows: Will this system work with my new Disc\Disc setup? I know it says Disc\Drum in the information, but I’ve read where many people us the non-power assist stock drum master cylinder with no issues. Below is the link to the referenced system on CJ Pony Parts website. Thanks in advance for the input to my question.
https://www.cjponyparts.com/disc-dr...master-cylinder-v8-bronco-1966-1977/p/BBCK23/
