Power Steering Burst - Fix?
GrillMaster
Jammed the front wheel into a wash crevice over the weekend in Dove Springs/Jawbone, CA. It spun the wheel around and I think it must have blown a seal because all the fluid leaked out. I made it 100 miles back home without power steering. It looks like I am leaking fluid from just above the pitman arm. Is this just a seal I can replace or do I need to rebuild the power steering pump? Will running my Saginaw pump dry kill it? It was whining a lot on the drive home.
broncnaz
If I remember correctly there are 2 seals in the area your talking about easy to change once the pitman arm is off. I would pull the belt off your PS pump it shouldnt have burned up but it could. Worst case you need a new one.
GrillMaster
GrillMaster
I believe the pump runs the water pump too so I couldent cut it. I have to look again to be sure. Just filled it up will PS fluid and crossed my fingers. It's a new Saginaw pump so hopefullt it survived!
From what I read from past posts I just take off the pitman arm and the retaining ring, start the truck and turn the tire to blow the old seal out and then replace. $10 at JBG. Sounds like something I can do in an evening.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Water pump should be on the same belt as the crank and alternator pulleys. Removing the PS pump would then allow the alternator and water pump to still function.
broncnaz
I've gotten seal kits at local parts store before so you should be able to get them locally. As for changing the seals well I've never done it that way but it cant hurt to try probably wont make to much more of a mess than you have already.
GrillMaster
GrillMaster
Took the pump off and its toast. the shaft is off to one side tellking me the bearing is dead.
Hopefully Napa has a lifetime warrantee on this thing.
Oatmeal
Look for a crack. When mine leaked like that I found that I had cracked the housing at the pitman shaft bore. At the time (about 20 years ago) used or rebuilt boxes were pretty pricey so, I had Lee Mfg in Sun Valley, Ca repair it and he added a gusset as well......no problems since. Paid (back then) about $500 for the box work and to have the stock pump reworked........before I knew about Saginaws----------Hans
