I have a 72 Bronco that has factory powering steering. I had WTOR rebuild it and upgrade to a 3:1 turn to turn ratio.
After all the other repairs new ball joint, lower steering shaft, wheel bearings and steering column rebuild I still have play in the input shaft of the steering box. I sent it back to WTOR for them to check it and they said it was all OK and it must be ball joints or something.
I have rechecked and even taken it to a local shop, we can't find the problem. There seems to be about 1/2 to 1 inch play in the input shaft before you feel any resistance from the box. With the 3:1 ratio at any real speeds above 45 it is really hard to keep from over correcting in curves and any other time a slight correction is needed.
Can anyone help with this. I am in over my head on what can be done the the steering box! I know there is an input shaft adjustment with a locking ring but can't find any information on what this does or if I can be tightened to get the layout of the inout shaft.
And of you guys that have rebuilt a box know what this adjustment does?
