I have the borgeson from CJ. Haven't gotten to use it much yet since the bronco isn't done. It installed fine. But has a different input spline size from the steering column, just be ready for that. I already had plans for a new steering shaft, so I got the correct size u-joint to go with it. I had to modify the pressure side hose to clear my exhaust header with the stock Bronco PS pump though. That Delphi pump should be no issue.
Sent from my SM-S916U using Tapatalk
