Another easy way (the way I do all mine) is to buy the Aeroquip (or Parker) steel 'female flare to AN-6 male nipple' adapter fittings that they sell pretty cheap. Screw those in to every place a hose would go and then have literally ANY shop that can make hydraulic hoses up, make you the ones to connect from one male AN-6 nipple to the other. The 37-degree JIC AN hose ends are about the most common hydraulic connection there is and you can have a replacement hose made or a hose repaired literally anywhere after you convert from the flare ends that are in the steering box, the pump (if its a Sag, whihc it should be) and the h-boost unit itself.
For my stuff, I use the Aeroquip TFE hose and the re-usable hose ends. So I can repair my chit on the trail by simply carrying a length of the hose and a hacksaw blade. But the crimped hose assemblies are fine too..and will be made of double-braded hose that is rated about 5 times the pressure of a power steering/h-boost system..way better than the factory hose junk is.
