Power Steering Hose Part No. ??
Brinco
I have a 76, originally non power steering but converted some time in the early 90’s. I believe it is an 70-77 f100 4x2 box but not positive and not sure about the pump. My pressure hose is starting to leak at the crimp and trying to find a replacement hose at various parts store has been challenging. I found a place that would fab a hose for me but it’s a little pricey so wanted to see if anyone can offer any help. I posted some pics of the setup so my questions are:
-can anyone confirm this is f100 4x2 box from 70-77?
-can anyone confirm the type of power steering pump? The pics have a remanufactured part no. But I couldn’t find anything online.
-anyone know a part number for a pressure hose that will fit from Napa auto parts, autozone or O’Reilly?
-will part #2117 from wild horses work?
Thanks!
B
Brinco
Thanks for the reply, unfortunately on that part the fitting with the female end is pointing straight out the back of the pump and I need it to be straight up. Just for clarification is the pump I have stock early bronco?
SteveL
Huge chevy guy
Hawthorne ca
Many of the old swaps guys had custom hoses made at napa to get the right fittings on the end. Another option is Earl's if you have one of their vendors nearby. Wh also has a variety of hoses and fittings for common swaps
sprdv1
REBEL
Never fails, always something...
thegreatjustino
Red Head Grease Monkey
Stockton, CA
It's silly to base an assumption the part won't work on a photo. Back in the day when this steering swap was popular, I did it to several Broncos. Walked into the local autopart store and asked for a pressure hose for a 70s two wheel drive Ford pickup. The hose I bought worked every time.
The power steering pump mounts to the 302 in a 2wd pickup the same exact way it mounts in a Bronco. If it works in the truck, why wouldn't it work in a Bronco?
B
Brinco
Thanks everyone for the responses. Justino I will agree it does seem silly but after looking on line and having two local auto parts store order hoses that supposedly would work it only took a few minutes in the parking lot to determine the fitting geometry was not going to work. gr8scott I was able to find that link but unfortunately it didn’t help with trying to find the correct hoses.
Had some questions answered today and should have the correct hoses tomorrow.
