Power window kits:
danroot
Our 72' Bronco has a generic electric window kit from roughly 2010. I'm not that impressed with it. Weak motor that drives a cable and the motor limits the down travel. I've seen kits from Tom's and Wild Horses, but they seem to use the stock window crank to some degree. Anyone have a kit they've used or seen used that works well in our EB's?
I'm keeping wing windows.
-Dan
widowmaker77
I saw a post on Facebook a couple years ago where a guy modified the bronco window regulator to use Taurus electric motors. Looked pretty easy to me. I’ve been wanting to give it a try for mine but haven’t got around to it.
bronco italiano
Make sure your window frame is not bent, and your seals are good. Do some window hand test runs up/down to make sure you don't have high friction areas
