Prepping for paint
rjcruz27
When I got my bronco some of the replacement panels had some surface rust on it. What do you guys find best to kill the rust?
Also I’m going to start removing paint for epoxy primer. As I expose the bare metal is there anything out there to protect it until I get to epoxy primer?
Rocko1012
Wire wheel panels clean of rust surface rust. Wipe down Use wax and grease remover. As long as panel does not get damp and you don't touch with bare hands it should be ok for awhile. prior to epoxy. I use AirCraft Stripper to get down to bare metal. Effective but messy. stripe on day epoxy next.
bronkenn
Bronco Guy
Southeast Ohio
Watch what primer you use. Some epoxy primers don't recommend any etch or rust removers under them. I have seen vinegar used to remove surface rust. Ken
