Primer/paint issues
ps6123
Denton
Ok this is my very first time doing a complete paint job on any vehicle let alone one I took down to the frame so a course I have run into a problem. I primed the tub, dash and inside part of doors, tailgate, lift and the top prior to Raptor lining them with no problems. Primer lated out smooth. I have now done my fiber glass hood and front fenders as well as my fender flares, window frame and the outside tub. Now the texture seems ruff.
The gun I'm using is a HVLP Devilbiss. I have a filter and water seperator at the compressor and one right where my air hose reel is at as well as a disposable one at the gun. My air pressure is right a 30psi at the gun.
Can any one tell me what I might be doing wrong?
Primer is Advantage 325, Activator is Advantage 326
Mix is 4 to 1
Thanks for any advice you can give a complete paint rookie
allenfahey
Rough texture or orange peel is caused by too thick if material, improper air pressure, or incorrect tip size. Was the temperature of the primer the second time cold? Not the air temp but the can, was it cold? That can thicken the viscosity. The way to fix that is to warm the primer or use reducer even though the ratio doesn't call for it at 4:1. Are you 100% sure you mixed the primer properly? If you left out a bit of hardener that can thicken it up too. The gun you are using is a decent gun but what size tip are you using? Primer needs at least a 1.7-2.2 tip. Too small of a tip it can't atomize the product properly and can compensate a little with more air pressure.
I'm going to guess if the mix and temperature was the same both times your problem might have been improper air pressure. 90% of HVLP guns needs 10 psi at the cap or 23-30 psi at the gauge. Try bumping ip the pressure a tad. One way to look at it is its only primer and the orange peel in primer can be sanded out.
BTW. Are you using HVLP fittings at the wall and hose/ gun connections? If not you are choking the gun.
P
ps6123
Denton
I am not sure about the air fittings? They are the same ones I use on my air tools. I have set the air pressure leaving the tank at 80psi and at the gun I have my pressure set at 30psi.
I forgot yo mention that when I shot the inside of my tub I used a cheap Walmart Spray Gun. I had way to much pressure going to it a blew the cup on it . The deal is it laid a smoother texture .
I will check my mixture and see about thinning it out a bit as well as my tip size
Thanks for the information
allenfahey
That makes total sense. The cheap Walmart gun you used probably has rather large tip. I doubt it will even have the tip size stamped in the air cap but it is probably a 1.7-2.0. The large tip size along with the high air pressure you sprayed is why it layed out smoother than the Devilbis.
HVLP fittings are highly recommended for a good smooth finish. If you use standard fittings you are seriously restricting the HV (high volume) part of the design of the HVLP gun. The LP (low Pressure) part of the name comes not from the air input but the air pressure measured at the cap. That measurement requires a special air cap with a gauge coming from it but is about 10 psi. HVLP fitting can be bought at your local paint jobber or online. If you need part numbers let me know.
For proper function of the gun you need HVLP fittings (also called high flow) from the wall or compressor, at least a 3/8" ID hose, HVLP coupler, and an HVLP fitting on the gun. Most guys use a regular "A" or "M" style on their primer guns because they spray in different parts of the body shop and a bit of orange peel is no big deal with primer.
If your Devilbis is a 1.3-1.5 and you want smoother primer you will have to reduce it a tad. I wouldn't go over 10%. If you bump up the air pressure then you will tend to waste material since it will hit the surface and blow away in the form of overspray.
A 1.3-1.4 tip is great for spraying sealer, base, and clear.
Does all that make sense???
Here is a picture of the size difference in the HVLP on my SATA compared to the "A" style on my DA.
allenfahey
I checked the TDS (Technical Data Sheet) for the Advantage 325 primer and see that the ratio for the high build is 4:1 which is rather thick. It also list a 4:1:1 ratio (primer, hardener, reducer) for regular build. That means you can reduce it further than the standard 4:1 ratio and still get acceptable filling. It is nice that you can also reduce it even further and use it as a sealer after the priming. That is what is listed as a primer sealer with the 4:1:2 ratio. Some paint lines use a totally different product for sealer which in your case is nice, less products to buy.
If I were you I would spray 2 coats of the 4:1 ratio with the Devilbis for filling. Then apply a couple 4:1:1 ratio coats to help smooth out the orange peel. Make sure to let each coat flash off.
P
ps6123
Denton
Ok
I defiantly don't have the right size fitting of hose. In the mean time what would you recommend would be the best way to take down the rough texture?
Wet sand?
Thanks again for the information
allenfahey
If you are going to re-prime I would guide coat it then block sand (dry) with P180. Probably a good idea for an amerature bodyman :) If you don't want to re-prime block with P320 (dry) and finish in P400-600. If there are bad spots you can start with 180 and reapply the guide coat and finish in P400-600. Make sure to get all the 180 scratches out. I like using 3M 05860 dry guide coat, it's a powder that works very well! If you break thru to any bare metal or body filler just spot prime with the 4:1:1 ratio. Prior to paint if you finish in 400-600 scuff with a grey Scotchbrite pad.
Another option is you can finish all your work in P320 if you plan on sealing the primer. If you do a red Scotchbrite is good to use.
E-coat parts you sand with 320, red Scotchbrite, then sealer, let flash, then paint. No sanding sealer:) There is also no need to prime e-coat parts and re-sand the primer. Huge waste of time and materials.
rastiss
Wichita falls, Texas
Its important that you stir/shake the primer well as the heavy fillers will settle to the bottom making it thicker the closer you get to the bottom as the resins rise to the top.
allenfahey
Excellent point! It's funny some things I don't think about :) I never worry about that stuff since my primers are always agitated when I turn on the mixing bank a few times a day.
u10072
Listen to what Allen has to say about paint! The air lines fittings are a big deal and worth the money and effort to use. almost seems strange but the fittings are important!
rastiss
Not just fittings, hose, lines too. I have thousands tied up in my air supply system. Kaeser refrigerated air drier, transair aluminum air tubing and fittings. SATA rep came through not long ago checking shop air systems and told me this was the first time he had NOTHING to recommend... I thought that was pretty funny, a salesman at a loss for words....
