deltabronco
- Dec 27, 2005
- 1,100
Any good articles about priming the engine? I put 5 qts of Rotella in, removed the distributor and attatched a hex rod and began rotating it counter clockwise. This was done rather easily and the cordless drill showed no strain. I did notice a small oil leak at the rear of the driver side vavle cover but identified that the bolt was loose. Question is, was the pump moving oil as it should. How long do i need to do this to prime properly? The engine was built 6 yrs ago and never cranked. This is the first time fluids have been put into it, other than an engine oil fog. Is there anything else i need to do, or anything i am doing wrong?
