Priming the oil pump
blubuckaroo
Grease Monkey
Ridgefield WA
If I prime the oil system before installing the motor, How long can it sit before start-up? I want to have the ignition system installed on the stand.
bmc69
Me..I always prime the motor as close to startup as I can....
Pretty long time. As long as the oil pan is full the pump will stay submerged and hold its prime. the filter will stay full as well.
But a fresh engine prime is really to get all the new parts soaked in oil just before you start it. I like to start the engine withen 10 minutes of priming but in odd conditions I wouldn't wait more then about a month.
I don't like to have the distributer in place while installing an engine. Too easy to damage with a lift chain.
Master Chief
I second what Bowsher said about the distributor. Quite a few years ago at the base auto hobby shop I watched a guy (not me) break his distributor off while installing an engine.
7elk
Albuquerque
I prime with the motor installed. At build time leave the motor on TDC and then drop in dizzy. Will start for fine tuning after good prime.
Madgyver
Bronco Madman
Prime it right before start up is best. Use an old dizzy with the gear knocked off, Chuck on a hand drill (corded not cordless) and crank it counter clockwise til you feel the drill labor.
blakerj10
Gillette
If you don't have an old dizzy, I used a 1/4 drive socket and extension on a drill. Taped them up so you don't accidently drop them down in the engine.
My engine has not been started in many years. Would it be a good idea to this again even though the cam has already been broken in? Or waste of time?
