pro/con on suspension
1974 Bronco
Fayetteville NC
What is the best Suspension for a 74 bronco stock height the TBP stage 1 Kit with TBP shocks or the Wild Horses Suspension system with Rancho rs 9000 shocks
bronconut73
WH with the Bilsteins.
The RS 9000's are nice if you off roading alot since you can adjust for street or trail but not worth it if not.
The Bilsteins will ride super nice....well nice for an eb...lol.
Hozr
Rogue Valley, OR
The stock "KIT" shocks are crap. They are bottom of the line shocks. I had the TBP shocks from the 3.5 kit and after a year they went in the scrap heap they were so bad!
I run the 9000's front and rear and the adjustability is nice when you need it.
No Hay
I've heard shocks can generally last about 12 months. They slowly degrade so you don't realize how ineffective they are performing.
It would be good to see all brands in a test, over time, for results.
needabronco
Prescott/Farmington
First off we need to know how you plan to drive. Cruising, bombing down fire roads, mall crawling, baja 500 style....
Most kits will do fine for general cruising, slow trail riding, and mall crawling (those curbs are a b$%^;D)
I personally rate Rancho below cheap parts house brand shocks. They are way over rated, ride rough, and don't last. My supervisor replaces all 4 Rancho shocks on his work truck (F250) every 5,000 miles, and yes they are completely shot by then. I've never had a set last more than 30,000, and have blown them up in less than 500 miles. I've run Bilstiens for several years and have never had a set replaced other than having 7100's rebuilt due to leaking seals (these are abused regurlarly).
Of the 2 kits you referenced I'd probably sway towards the WH system because of the 10 leaf spring packs over 5 leafs, 10's should ride smoother than the 5's. But again if your generally mall crawling it won't matter. I'd ask if you can upgrade to Bilstien 5100's instead of the cheap house brand shocks the kit comes with.
Shipping will most likely be another thing to consider. If you ask both parts houses will work with you on shipping. If Jim is coming out to a Bronco event near you in the future, he has been known to bring your order with him for free shipping. You just gotta ask.
