Yesterday, I got a good 8 hours in the garage. So I finished up the wiring from the starter solenoid and painless alternator fuse, to the starter and alternator. Now that I have the location for the Vintage Air dryer. I was able to loom and route the wires around the battery tray area to the electrical mounting bracket along the passenger fender.
Once I had that loom in place. I put together the battery cables and route, the cables to the battery.
After finishing this wiring. I decided to move on to something different. I have the James Duff hidden wench kit. So I thought it would be a good time to fit the kit up before I proceed with the a/c condenser and radiator install. As with everything else. The bracket mounting holes did not line up perfectly with my frame. I expected this because I had added 1/4" reinforcement plates to the frame at the power steering mount area. So two hours later with 5 new holds drilled and some added clearance ground on the bracket. It all mounted up pretty well. It was getting late, so I will post picture of this install next time. That is it for now. You all have a good Memorial Day. And a big Thank You to all our Veterans and service men and women out there. Protecting our Freedom!
