Project grocery getter
P
ponyracer
Crestview, Fl, 32539
LOL na, ran out of daylight and days off. I got her going down the road again, I'm taking thurs and friday off to finish up the top and do the rockers, hell maybe even paint her.
A couple things noticed:
1. DO NOT get kyb's for a lifted truck, OMG they ride ruff.
2. Schd 40 2.5" structural steel works REAL well for a Dshaft extention, get one with no inside lip and it's a pretty tight fit, index the stocker and weld it up. No vibes to speak of to 65 mph.
I'll get some more pics up soon!
FRANKO289
Bronco enthusiast
wow ... nice work ... cant wait to see it in person !!!
englewoodcowboy
Lick Creek Restorations
A word of caution, you may not feel any vibes but the seals and bearings will. You may be extremely lucky and get it right but I would have it balanced to be sure. You will know in short order if it is out when the seals start to leak. This kind of repair for a driveshaft can and will usually be OK for a strict off road vehicle but running it up and down the HWY is a lot of RPM's on that bad boy.
P
ponyracer
I normally index them and shorten them by cutting the weld and using a tubing cutter on the shaft. Haven't had a prob yet! This one is temporary anyway, will be going with a 31 spline carrier, new larger yokes, and a zf5 if I can ever find one. But ya, you're right, I'll watch the seals just in case.
I just picked up the 2x4x1/8 rect tubing for the rockers, rolled up some sheet metal at work today so I can rebuild the back of the top. Going to weld in the back glass and redesign the corners, think 1970 corvette back window with the "pillars" on each side, maybe not to that extent but the same idea. On the way to autozone to get my new ps pump and rear calipers for my disc swap that will start in a couple weeks.
englewoodcowboy
If I still lived in SW FL and u werent so far, I had a good friend with a salvage yard down there that had some on a shelf. I have been out of touch with him but you can give it a try... GulfCoast Towing and Salvage in Englewood, FL.
P
ponyracer
I hate plumbers caulk. A few spot welds and a tube of plumbers caulk to hold the floor pan in. Ugg what a pita. A little rust and and I wind up taking out the whole floor.....
Finally got around to working on the rockers, got the drivers side mostly done.
Need to finish the floor and get the drivers side done, then onto the pass side.
P
ponyracer
Got the drivers floor ready to go back in, finished up the drivers side rocker, mostly finished the pass side rocker, got the back window stripped of hardware and tacked in place.
Here's a few progress pics of the pass side rocker.
P
ponyracer
I'll take some tomorrow, I've been meaning to for awhile. It's a 2 into 1, 2 1/2 into single 3", then up over the frame and the muff is between the frame and the body.
broncoitis
ponyracer,
Awesome job so far. Are you doing all this fab work by yourself? Either way, great job! Can't believe the progress you are making and love what you did with the exhaust!
Rob
P
ponyracer
Ya I do all my own stunts lol. The only thing I don't do it tranny work. I'll put in shift kits etc but I don't rebuild em.
Here's some pics of the exhaust
Here's the only spot where it hangs below the frame, when I put the zf/205 in and clock it I'll redo the exhaust to keep it all above the frame. The can of bondo in the pic is a gallon can just for reference.
P
ponyracer
Where the exhaust goes over the frame is close but theres about a 1/4 of clearance. Here's some more random pics I've been meaning to put up.
Here's one more.
Here's my $175 steering shaft from bc broncos lol.
My gaping hole in the floor lol.
Here's my tilt column from an 89 ford van. Got the blinkers wired up but not the key yet. Maybe this weekend.
My msd hiding spot
P
ponyracer
Got most of the rockers cleaned up and both sides are skim coated with bondo, tomorrow a good sanding and maybe a little primer.
Also picked up another piece of 1" sq tubing to fill the gap left by raising the back glass up. Need to get the floor patched, and the top done tomorrow.
