Project Springtime or Busted!!!
jmhend
Herman, sorry for not extending the offer to you as well. If you are up for the hike. I am about another hour west of Rob.. The more the better. I will provide your favorite beverage and a meal. Maybe even two if you stay long enough.
Jason
broncoitis
broncoitis
Rob is crazy! I have never met anyone as anal about placement of everything as Rob. But it will guarantee for a nice looking Engine compartment! ;D
Yeah, I am crazy about making it look Nice and Tidy! However, when its done you are gonna wanna fix yours so to me, its like do it right the first time and hopefully don't do it again! %)
Jason, if you need help with the wiring I would give you a hand. However, I am anal about doing things nice. I have to warn you! LOL! :cool:
broncoitis
broncoitis
Worked on the under dash wiring before heading to work this morning and some good progress. Still looks like a mess under there but once I put in the Dash and glovebox, the relays and fuse block for the EFI will be mounted to the back and side of the glovebox respectively.
Should be nice and neat and even better not exposed to the elements in the Engine compartment.
Here is a pic that shows the progress but like I said it does not look like much but there is still progress. ;D
76 bronco J
>>> I like the way your EFI computer is mounted correctly with the connector at the bottom & having good access......noticed you said you are using a RJM harness....is it the universal 5.0 harness??..... one of the main thing I dislike about the bronco specific RJM harnesses is how everyone has the computer mounted up high & sideways because the wires are so short going into the cab...........
tasker
all knowing of nothing
NH
rob, insane attention to detail....this is gonna be a beauty
tasker
NH
I personally do NOT have a problem with that!
broncoitis
broncoitis
76,
You are correct about my selection of harnesses. I decided to go with the universal harness vs. the Bronco specific harness. For once, it looks like I made the right decision the first time! ;D
It definitely has some room to play with where you mount the computer but I honestly think that the Passenger side Kick panel is the best option and in this case was the only option. The bracket that I used is the original mounting bracket from the Mustang and it worked out well in this case.
broncoitis
broncoitis
Thanks Tasker! Just trying to keep things organized as best I can! Planning on hopefully getting alot done tomorrow. %) Should be able to get the dash reinstalled and hopefully get most of the rest of the EFI installed. Also have to mock up the condenser in front of the radiatior. Can't wait to see how that goes. %)
broncoitis
broncoitis
If there is anything less than perfect on the wiring I can be to blame. Im pushing the guy to have it ready for BYOB and testing beforehand ;D
Don't believe anything that Herman says! Although we haven't gotten together and wrenced on this thing all the time he has definitely helped with his unique ways of motivation. :eek: LOL!!!!
Besides, GUMBY needs a FRIEND!!!!!
br0nc0xrapt0r
Loves pickles
It is the Mallory frame mount and it will put out up to 55 psi. It should be able to put out what the EFI is gonna need! Here is the link from Summit racing:
http://www.summitracing.com/parts/MAA-4060FI/
If you are over in Afghanistan, God Bless and come home safe! Thanks for all you are doing.
Yep I'm in Astan, there is a thread on it in OT Thanks for the link to the pump. Sounds like what I need for when I get back and do my efi swap.
broncoitis
broncoitis
br0nc0xrapt0r,
Haven't tried the pump just yet but should be cranking things up in the next couple of days hopefully! Be safe and get back home and work on that Bronco. ;D
broncoitis
broncoitis
Wanted to get more done today but ran into some obstacles that had to be fixed. Basically noticed that the return line coming out of the heater core was pinched and that obviously had to be corrected.
Also had to finish the modifications to the heater defrost vents in order to reinstall the dash. That took longer than it should have but came out good so I am happy. Also, welding plastic is a pain in the BUTT. :eek: However, once i got the hang of it, it went pretty fast.
Got most of the dash reinstalled and the evaporator is DONE!!!!! ;D Only thing left to do now is get the new compressor and mock up the condenser and drier so that I can get the radiator reinstalled and Fire it up. I can honestly hardly wait.
The wiring under the dash came out pretty neat so that is a good thing and there is definitely alot goin on on the passenger kick panel and firewall area.
The install was a royal pain in the ASS but I personally really like how this Gen IV works out in the bronco.
Here are some pics of today's work.
fGonna hopefully get the EFI and VA wired into the keyed ignition tomorrow and prep the upper Manifold for its installation on Tues.
broncoitis
broncoitis
Oilpan, who needs an oilpan????? ;D
Actually, that is going back in place tomorrow. Now that the weather is getting decent, don't need any unwanted guest making their home up in the engine.
broncoitis
broncoitis
Got some more things done on the truck today. Wanted to put in a full day working on it on my day off but other things got in the way. Anyway, this is what was goin on today:
- reassembled the throttle body.
-painted the remainder of the firewall holes that I filled.
-mounted the upper intake and throttle body.
Wanted to get more done but that was all that the time allowed. :( Oh well, always tomorrow after work. ;D
broncoitis
broncoitis
Ok, made some progress today! Doesn't seem like alot but alot got done but getting the oilpan back up in place took some time but it is back where it belongs. Also mounted the Barometric pressure sensor and working on getting the condenser in place. EFI conversion is just about done as well. Only things left to do with that are the O2 sensors, the emergency kill switch, wire up the "Idiot Light" and Fuel Pump. After that, see if she will run. ;D
Plan is to tie up alot of loose ends tomorrow!
englewoodcowboy
Lick Creek Restorations
Beautifull work! I am really glad I found ur thread, raising the pass cowl has turned out super nice. Looks like it was how it should have left the factory.
Wyflyer
I might have missed this somewhere: did you buy the Bronco specific Vintage Air kit, the BCB kit, or a non Bronco kit? Or are you piecing it together? I read somewhere that you were waiting on some hoses and condenser? Backordered or ordered separately?
And what is the difference between the Gen II and Gen IV?
I'm wondering what the kit looks like in a Bronco with original dropped cowl, not raised, does anyone have a pic of how low it sits?
I'm shopping for a Vintage Air kit, planning on BCB kit.
thanks
broncoitis
broncoitis
Thanks Englewood! Just trying to get it on the road at this point! Unfortunately still too anal to cut corners. LOL!
Wyflyer,
The biggest difference between the Gen IV and Gen II units is the price. However, I think that there are some advantages to the extra price for the Gen IV.
- the first advantage to the Gen IV over the Gen II is that the evaporator is much more centered in the middle of the truck vs. sitting all the way over on the passenger side of the truck.
- the second advantage as a result of the better positioning on the firewall is much shorter ducts to the different locations on the dash.
- another advantage in my eyes is that the ducts exit the side of the unit vs the top which I think is much better.
- the exits for the floor heat are also properly positioned in the center of the firewall where they should be located and not all the way over on the passenger side where you have to run a duct over to the driver side to get the floor heat over there.
- don't know if this is an advantage but there are 4 vent outputs vs. 3 that are on the existing kits.
- finally, and what I think is the biggest advantage, the unit is engineered to compensate for the step in the firewall of the bronco which the other kits cannot compensate for.
My install is completely custom because there are no existing kits available for the bronco. There are also things that I have done to increase the difficulty of my install like putting the heater control valve under the dash and not in the engine compartment. If you look at some of the older posts in this thread you can basically see where the unit would basically sit with an original style firewall because the welded seam is very visable. However, there is a thread where Bax installed the Gen IV as well and a good pic of how it would be positioned with the uncut firewall.
Hit me up if you decide to go with a Gen IV and im sure that I can offer some usefull advice considering I have already done the install. Having said all that I feel that installing a Gen IV vs. Gen II would be basically about the same in terms of difficulty. Good luck whatever path you take.
